Wanted Scout II 5.25" Air cleaner base
FDChappie
Well-known member
Interesting discovery. Now that the Scout is setup with a 4bl carb, I go to close the hood and it's a no go. It seems the Scout II's use a low profile air cleaner and the 2 d series one's I have won't fit under the hood.
So does anyone have a stock air cleaner housing they want to sell from a Scout II with a Holley or tq carb??? Prefered is one with no emissions hardware. The reason for wanting a stock housing is that when fording or going through a deep puddle I've seen engines die due to exposed elements getting wet.
I've got mucho IH parts to trade or there's always the almighty $.
Yes just the base is needed. It will be a special dropped base for a Scout II. There will be a recess in the front to clear the water neck. If either of you has one that would be great.
Thanks!
Sorry. Forgot to look last night. Got busy installing my 4bt for the last time. I'll check tonight.
This is what I have. It's off my 1980.
this is what I have. It's off my 1980.
If that's got a 5.25" opening in it May work, but let's see if a non-smog unit turns up. Thanks for the pics.
I wanted to do a diesel conversion on my Scout with a vt275, however finding one for less than $10k was an issue.
