Voltage checks?
Scooter
Active member
In regards to finalizing the install of hamilton TBI.
Ok, I'm stumped and couldn't find a list of what specs should be on the mythical voltage checks.
I know the first thing guys want to do when hooking up their fuel injection set up is to start it up and hear it run....
after you performed the voltage checks!!
Either I'm starting to get alzheimer's disease or I'm missing something. Searched through this forum and others and still couldn't find a definitive list of which parts to check along with what the voltages should be. The info just might be spread out inside multiple threads.
If you're installing my system then no voltage checks are required. As long as you have it installed per the installation manual all is good. 12v on starter and 12v from the switch to the small pink wire as shown. No ballast resistor.
Thanks bill.
That confirmed my thoughts. But I wanted to double check. Overall an easy install and well laid out. Hopefully I'll get the owner of this install to start up a build thread of his 69 800 where your kit is being installed.
As a side note, if one was piecing together a kit, what components need to be checked? Along with what voltage specs?
If you look at the wiring FAQ at the bottom it specifies to perform the voltage checks listed on sheet 1 of the diagrams.
In the parts required FAQ there are additional specs for the individual parts.
