Alright yawl. The fat white boys got us a sitsheeyashun with one of our fleet rigs. This be johnboy's '77 sii with 304, 727, d20, 3.54 open diffs sitting on stock suspension and small tires. This rig was a dead dawg reskew about 14 months ago. Now it's a solid driver. Ever since we've been able to drive it, we've noticed a steady growling noise once a certain speed is reached. The rear wheel bearings and brakes were done a couple months ago with no change to the noise. There is no slop in the rear drive shaft at either end. There is no u-joint clunk when the transmission is engaged. When moving slowly in either forward or reverse, the thing is church-mouse quiet. The noise only rears it's ugly head once a certain speed has been reached, and then it is steady and related to some rotational speed. Coasting has no effect. Neither does shifting the trans from d to n at speed.
Earlier today in an attempt to isolate the noise, we removed the rear shaft so that we could run on the front axle. Immediately I noticed the shaft was about 45 degrees out of phase. Naturally johnny and I were quite excited thinking perhaps we had found he culprit. We went ahead and test drove it on the front axle only. The noise was gone. When we got back, john removed the slip joint which was one spline off and re-installed it in phase. We then put the shaft back in and went for a drive fully expecting to share high fives, only to be disappointed, as the noise was back. So what does all this tell us? Tia
couple more things...yes we've had the diff cover off and did not notice any obvious issues. Yes the diff is full of gear lube. The t-case is full of 50wt. Motor oil.
