Craig
Active member
Good stuff. Chad brought up a really good point and that is sprung under vs over. I guess the write up would be the same except which housing gets used, as the pad is on top with a Chevy axle
something else to consider for an ultimate 44 axle would be a high steer setup. And if you want 1 finger steering your going to need ram assist too
might as well tossing one toe brakes while your getting everything setup.( hydro boost brakes) ok ok I know I broke the bank, got off topice but you would be surprised at the number of setup's out there.
