Mark Ashford
whaddya call it when you do it for the rear axle? Rear dig?
Old thread, but since someone already bumped it this year....
The rear only is called a "rear burn", or is sometimes called a rear dig.
Fronts can also be called "front burns" but are usually a "front dig".
So where's the write-up on twin-sticking a d20?? Without a tear down. I guess there is a special "pattern" of twisting and pulling to get the shift-rails out without a tear down to remove the pills....
So if you take a "standard" Scout II Dana 20, and just twin-stick it without any shift-rail mods... What modes can you not get?? I know with a Scout d300 you loose the option of "front high only"... But I know for a d20 its different......
