72scoutII304
Ok im going to be replacing my clutch and I would like to know what would be the best way of going about dropping the transmission.
the other key is to get the rig lifted up off the ground evenly as high as you safely can do. The problem with a trans on a trans jack is that even with it bottomed out, you still have to be able to clear the exhaust pipes and frame.
just do not use cinder blocks. Had a local guy suffer a long lonely and agonizing death after a cinder block that was holding up his car crumbled while he was under it. Someone found him still stuck under the car a couple of days later. The fd in my handle stands for fire department.
