Fishwagon
Hello all,
well, finally got my t-case rebuilt, so I put everything back in the Scout.
Reverse works great, as does first gear. Really made quite the difference (rebuilt tranny with a B&M kit supplied by IHOnly).
However, the transmission won't shift into second.
I have tried the following so far:
1. Adjusted kickdown lever
2. Removed and checked the operation of the governor.
I will be doing the following today:
1. Check to make sure the kick down gizmo is working the valve on the valve body
2. Disconnect the kickdown lever from the tranny to see if the tranny will shift.
Now, in case these don't do it, does anyone else have any ideas to check?
Also, if I do not put the t-case back on, as well as rear driveshaft, will I still be able to detect the shifting of gears using the tach to see engine speed changes? I really don't feel like putting everything back together for a road test if I can help it until I have a reasonable expectation of success...I have enough cut hands, tranny fluid, gear oil, etc....all over me and my driveway....lol
thanks and have a great day!
Rich
Rich
