All tf 727 (IH code t-407) transmissions in all ihc-produced vehicles (including motorhome chassis) use a heat exchanger in the driver-side radiator tank (cross-flow radiator). Same for all 727 apps for any other oem, chrysler, amc, etc.).
The transfer case in a Scout II is "married" (direct-coupled) but does not share a lubricant supply with the transmission. The heat exchanger is only used with the 727 transmission.
The very earliest Scout II is more commonly known by it's model designation..."810". Those could have had a borg warner auto-trans. Many had an optional marine-style heat exchanger plumbed into the lower radiator hose with a return line tee'd into a heater hose, however, they had an air-cooled torque converter which incorporated a cooling fan in it's design. The same transmission setup was also used in the Scout 800 (with and without heat exchanger) and in pickalls of the same era. 4x4 Scout 800 had a married transfer case, the pickalls have always used a divorced transfer case in 4x4 option.
This thread will be moved to the "transmission tech" sub-forum.
