Total Timing - Recurve Prestolite Distributor
RALLYE
Anyone change out the stock heavy springs in their distributor to achieve earlier mechanical advance? My goal (in addition to 2700-2800 all in mech. advance) is to achieve 32 degrees total w 17 initial, 15 mechanical. Does this sound reasonable for a 345? Conservative, too agressive? My late model prestolite had heavy springs in which didnt allow all the mechanical advance till past 3500rpm. I'm in process of trying multiple springs combos / bending the tabs their on to achieve approx 2700-2800rpm all in. Pls share if you got any experience with this. Thanks!
Scout II, Rebuilt 345 balanced, port n polish, headers, isky split cam 252/262, Sniper 4 barrel, Running 91 octane, Autolites .40 gap, Breakerless Prestolite Dizzy w 15 degrees mechanical, vacuum can 20 degrees (reduced to 11.5 so i can run higher initial)
