I hope this is not off topic once my torqueflite is the a-904-la behind a 318 rwd v8
the tranny is a 1976 stock, never opened until now, it has around 90,000 miles from which only 8,000 miles driven by myself.
I found the forum o be the most informative and thorough I have been through and thats why I decided to post here.
Once the car is a kinda collection vehicle now, I just want to keep it running after a long 15 years garage sleep.
The only complaint I had from the time I was driving the car is that it always felt like slipping in 3rd (d) when climbing uphill steep roads, it would show a 500 rpm increase for the same speed.
40 mph shows 2,000rpm and 2,500 rpm on a steep road
50 mph shows 2,500rpm and 3,000 on a steep.
I am not sure if the rpm increase could be due to a sound reason like the stock non lock up torque converter, or something else.
Neither it slips in reverse nor in 1st gear (so, front and rear clutches are ok? Bands I could see are ok and overruning clutch should be good).
I finally droped the pan and took the valve body out to look at the bands and drums and for my surprise, fluid was pretty dark but still red, not burnt, inside case walls clean and the bands where not loose ( I am pretty sure no one touched the rear band).
https://imageshack.com/I/iqommyfej
The pan has no magnet and had quite a bit of residue which is what concerns me, link below for the pics of the pan as it was dropped.
https://imageshack.com/I/ex1dz5zhj
Looks like alot of gunk but after scraping it to 1 pile I think it was not too bad, perhaps...?
https://imageshack.com/I/idnhggqtj
https://imageshack.com/I/iqmn6fbej
(scroll album left for 904 pics, right to 46re another issue)
another detail is that when I bought the car I recall the throttle rod was off almost 3/4" and I thought it was supposed to be like that (never had a tranny manual or tranny experienced mechanic). Tranny always shifted great at right speeds, good kickdown, no complaints except the slipping on steep.
Here is a link to a 1st set of pictures I took showing the pan residue I'd like to be commented for someone experienced if possible.
I have collected all solid residue, washed it in solvent and filtered through coffee filter and sifted to separate coarse from fine particles. I'll post some pics of the residue later if anyone in interested.
https://imageshack.com/I/p4yvxpjbj
https://imageshack.com/I/idrbwsw4j
https://imageshack.com/I/f0s7g0thj
I plan on installing a transgo tfsc shift kit, adjust bands, place magnet in pan, new manual shaft seals, new rear seal, new filter and fluid, adjust throttle rod and re-check slipping condition.
https://imageshack.com/I/f0oask2mj
Any advice would be appreciated...
