Michael Mayben
Running off battery power and a cell connection once again. A small generator is keeping us "up" right now but the phone/dsl system is down and out also. Many more trees came down...tons of cleanup to do...again!
So this post May not make much sense, once we dig out I'll be back!
No...a tf-3 kit I will not install inna street-operated rig, that is a "purpose-built" valve body install only!!!!
The shift kit would be a transgo tf-2 kit. The "shift command" portion of the installation/mod enables a feature whereby the trans can be placed in first/low gear at any speed by moving the shifter to manual low/1!!!!!! Look at the lead-in to page 165 in munroe.
You can well imagine what might happen when that is done inadvertently at speeds above say 30mph!!!! Onna trail rig, ya could easily experience total loss of control in an instant....but it could also save yore azz inna "last ditch" mode if ya know what is gonna happen...I have my tranny set up with that feature...and in some serious offroad stuff several years ago where I was onna downhill where I should never have been...I had to use that little "jerk into low" scenario and it saved me from going over sheer drop into a canyon, the loose surface prevented any kind of modulated braking action, the rocks were teh size of softballs and larger with no traction at all...but engine braking saved the day.
Gotta go, we're loosing power agin inna major storm...I'll be back!
hi michael,
I assume you mean the "tf-3" version of the transgo package when you are talking about the "shift command" feature? If so, then no, I do not want that. I would like the tf-2 installed in a full throttle kickdown valve body instead. If you are talking about something else, let me know. Thank you, and everyone else, for all of your help.
Last question, since I am going with a new tranny, I think I should get a new torque converter as well. I don't want to contaminate my new tranny with pieces of junk from the old one. Any suggestions for the correct torque converter for this 392 application?
