jauringer
Hey guys, wanted to discuss torque converters for the new engine.
My spare 73 torqueflite is currently torn down and I'm in the process of cleaning and collection parts for the rebuild. It will be mildly upgraded over my stock 72 unit. Part throttle kickdown being the big one along with a bolt in sprag, billet servos, hd retainer, hd strut, tf-2 kit, etc.
It's going behind a 304 60 over, isky split duration cam, roller tip rockers, gasket matched in/ex ports, bowl work on the exhaust side .....all that. Needless to say, I've pushed my power band up a bit. It's hard to say how much but my guess is 400-600 rpm
the most difficult decision I've had with tranny rebuild by far is the torque converter. After a few days of reading, performing specific tests on my current 727, and talking to dacco transmission, I feel like I know where I need to be. Certainly not sure though.
My current worn out tranny stalls 1500 rpm which has been fine with my old worn out stock 304 but I don't think it's ideal with the new setup. A couple things I've noticed.
1st. The truck seems to take more brake pressure to hold still at a light. I can get up to ~7-8 mph just by letting off the gas.
2nd. 1st gear takes longer to build up. It's still strong right off the line but I'm still a ways away from my ideal rpm range and I can feel it slowly building up after that first jump. This one isn't huge but I think it could do better.
3rd and most noticeable is the 1st to 2nd gear shift @ above average throttle. It's a steep drop from 2.45 to 1.45 ratios and when I really get on it my 2nd gear shift drops too low in the rpm range and it slowly builds back up to peak power. I think raising the rpm @ the 1-2 drop just a few hundred would a big difference.
No, this is not a racing Scout but I love to drive.
the dacco guy recommended a performance 2300-2500 stall. That high of a number scared me a bit and I'd certainly rather be too low than high. I hit 70 @ 3000rpm so @ 2500, the converter would be slipping most of the time.
I'm thinking 1800-2000 rpm stall would be ideal. That give me a solid 300-500 rpm bump which I think would be beneficial. What do you guys think? Anybody run a similar setup with a higher stall tc?
Thanks!
Jason
Thanks!
Jason
