Got the carb today and took her out for a spin. Drives much better. I need to make sure the timing is still where I want it, maybe I can take a little more advance now that the fuel is right. I still find that it lugs down some when coasting out of a turn. For example taking a turn in a residential neighborhood, I'll slow down and be in second as I go around, then when I finish the turn and want to accelerate it gets hung up a little. It May be a matter of technique too, since if I keep the clutch in around the turn so I can rev the motor some I can make it work out better.
The steering seems much better now. I found that my u-bolts were not nearly torqued enough after I put the lift springs on. I tightened those up and put the washers between the springs and shackles to tighten that up. I think the whole suspension was sloppy before which was making it wander.
I'm feeling pretty good about it now. Next up I'm thinking about some lockable storage so I can park in town, some sort of spare tire mount or hold down, and some skid plates before I take it off road. The clutch stuff looks vulnerable to me.
Thanks for all the help. I'll post up some better pictures soon. I think it looks pretty good, though the body needs some professional attention.
