What up all! It's getting that time of year again down here in texas. Weather's been perfect for a cruise in a topless Scout the last couple days. Hopefully we can keep it like this for while this year.
Well, there's been some more work done, we've got a running engine to go with it :d
here's a few recent pictures. I threw the engine stand together with as much scrap/ spare parts as I could and broke in Matt's engine.
Basic gauge setup w/ tach, volt, oil pressure, water temp. Also installed a remote start solenoid, battery and coil kill switch.
Black switch on the bottom left is the wideband o2 power, the green light is the idiot light for the alt (only color light I had left).
It still lacks an electric fan as well as a tray for the gas can.
Spare wideband controller and a nice little jerry rigging of the exhaust connection.
Here's a profile. I used a tiny air cleaner to give me better access to the carb. I broke it in without the alt but then later wired it in to check it's operation. It's was just rebuild by a local shop for something like $45. They even sandblasted and painted the oe case. Works perfect. The small gray box around one of the spark plug wires is an alternate tach hookup for that gauge.
Here's a couple just after inspection of the lifter bore, lifter rotation, and top end oiling.
Preparation was quite thorough as we went through all the wiring with a multimeter, verified plug wiring and connections, verified distributor phasing, battery charge, fuel level in fuel bowl, and tried to eliminate as much air as possible from the cooling system. Then we pre-oiled the holy hell out of it and stabbed the distributor at ~5 btdc (compression stroke) on the #8 cylinder. This all netted a very uneventful break-in. Everything went according to plan and the engine ran for 30+ minutes without skipping a beat.
Immediately after break in we shut her down and changed the oil and filter. For the engine build, I used all Joe gibbs.. The assembly grease on the cam lobes, distributor gear, lifter base, and timing gears; the high viscosity lubricant on the valvetrain, bearings, lifter bores, just about everything else. We broke it in with the 10w30 break in oil, followed by the conventional 10w30 hot rod oil. Matt will run this oil for the next 500 miles.
Matt is a private pilot so his traveling has given me the time
to run the engine a little more, tune the carb, adjust idle, set timing, as well as run several other tests inspections before it goes back into the truck.
It's still very early but I have done quite a bit of inspection and testing on this engine since the break in. That along with a relatively good knowledge of the typical sv, there are a couple observations I've made that I feel very comfortable stating at this time.
1st and foremost, no, oil pressure is not inline with a small block Chevy now. She's not idling at a 40psi or something nuts like that.
She idles at a steady 15 psi based on an a new sunpro gauge (what ever that means) fully warmed up after a pretty good session through the rev range. She's just under 50psi fully warmed @ 2000 rpm and by the time I crest 2500-2700 rpm she's limiting out @ just under 60psi. Her continued climb into the upper portions of the rpm range seems the most interesting to me regarding oil pressure.
The two most interesting observations thus far have been:
1. As as much clearance as we eliminated at the lifter bores, if it's not showing up as a large increase in oil pressure it's got to be going somewhere. Well, I can say with confidence that the majority of it has gone to the heads. The amount of oil this engine is sending to the valvetrain is without a doubt an improvement over stock. My half cut valve covers quite helping at just over idle now and I can make a mess of the place without even trying. Thankfully I did chamfer the oil returns back to the valley, plus I'll recommend that he continues to run at least a half a qrt over full.
2. Lifter stability has improved dramatically. Lifter and pushrod rotation is much more pronounced and at a much quicker rate. I think this will provide him great benefits in the lifter/cam wear department.
The last thing I'll say about it at this point (just an opinion here) is the engine is much more well balanced for choosing the proper oil. We build these engine closing up all tolerances on the bottom end then leave the top end in it's stock, leaking like a siv form. When we do that, I feel like we're seperating the engine into two halves, both with two different requirements for oil viscosity. The bottom half May want 10w30 where the top half wants 20w50. Yes, this May be over thinking it a little but you can't deny the imbalance in the engine afterwards. My next step going forward is to figure out a way to create a more stable top end oiling system. We're very lucky to have shaft mounted rocker assemblies but it's a fact that they leak terribly in several areas. I can't imagine how much the bolt holes and stands leak all by them selves. It's no where near a closed system up top imo.
Last but not least was the break-in filter cutting ceremony. I finally invested in a real cutter so I didn't have to decipher between cut off wheel shavings and the rest. I followed the procedures that an airplane mechanic recorded on the net and cut the filter material in short sections, spread it out and sprayed them out with break cleaner into a bowl, then filtered it all through a blue shop towel. It's a much easier way to get an overall look at the situation. You can even fold it over and label it for later comparison. It was a refreshing site to see as there were zero non-ferous metals that I could find. From the filter and bore inspection, our bushed bores broke in very nice. Here's a pic for you below. I made the mistake of stirring the solution going through the filter so I made a little "fuz" at the bottom. This is with flash on so hopefully all the little "sparkles" will come through.
That's all for now folks but at this point I've found no reason to delay putting this engine back in Matt's beast and letting it rip! I'll of course be monitoring the situation and have insisted that he install mechanical gauges for both oil pressure and water temp. Other than the engine, this is a very stock build so he doesn't want them visible. They'll be hidden in the engine bay somewhere next to his toilet paper filter for regular monitoring and recording baselines.
I will continue to update this thread as we progress along.
Jason
