Tie rod ends
Richard
1977 SSII, 345 / 2bbl / 727 tf / 44's front and back
on tie rod ends (the ones with the grease fittings) , does anyone know if the "plate" that the grease fitting screws into are pressed on the tie rod casing? It looks as if the plate is stamped steel while the tie rod end is a "one piece" casting.
Reason for asking is that I have four ties rods that have been sitting for about 15 years and want to clean them up and use them (new dust boots, castlehead nuts, and grease fittings). Also, is there such a thing as self taping grease fittings? Can't seem to locate any. Or do I just drill a hole into the blank plate and screw in a new fitting?
Thanks,
Also posted this on sw
that plate is swaged in and not removable.
The typical zerk fitting tre's take are self tapping 1/4-28. Kinda look like small tapered pipe thread. Common at the local auto zoo in packages of 4.
Drill a 15/64 hole to take the fiting
