Hi there, need some help.. My vehicle is a 1980 IH Scout II traveler with an 82' model 345 v8 out of an IH bus. Recently installed due to issues with former motor (stuck valves). To my knowledge the automatic is original to the Scout, only rebuilt. The engine that came out of the bus was bolted to a 5 spd direct drive transmission. I unbolted my old (at) flywheel, the crank hub spacer, and reinstalled on the 82' bus motor. No problems. The issue comes up that when trying to mate the tranny to the engine, the torque converter mates up to the flywheel, leaving a 3/4" gap between the tranny/ engine bolting interface. I can not get them flush with each other. I separated them, took measurements in several places using a straight edge and engineer's square. I have 1/2" from the bolting surface of the flywheel to the face of the mating surface of the engine. I have 1/4" from the bolting surface of the torque converter to the face of the transmission case. I cannot get the torque converter any farther up inside the transmission case. The final time I removed the torque converter, I notice the transmission input shaft seal rubber was slightly deformed, I couldn't reshape it, so I popped it out, thinking it was preventing full engagement of the torque converter with the input shaft. No difference in measurement, still 1/4". Ideas? Other areas to check? I cleaned out the torque converter, looked down inside the engagement collar, nothing appears to be amiss, same thing with the input shaft of the transmission. I think a new torque converter May be the solution, but don't want to start throwing parts at it. Need help... Thanks guys.
1980 IH Scout traveler w/ 82 IH 345 bus motor (originally Scout 345)
tf 727 believed to be original to truck
Scout d44 front axle
GM c&c 14 bolt rear
Scout Dana 20 transfer case (swapped out d300)
fuel injection
GM disc brake system (8 lug)
Holley distributor w/ GM 8 pin hei module.
GM c&c 14 bolt rear
fuel injection
