Anyone who wants to learn slushbox tranny work has to start somewhere! And plan to scruu up stuff in the process! I've been doing the 727 since '68 and still scruu up stuff.
The biggest issue is "tools" and how to do workarounds for that.
To remove the front pump, ya need a slide hammer setup with the proper adapter to thread into the pump cover. Preferably two slide hammers or a pair of home-brew slappers made from allthread.
Ya need a method to compress the clutch paks for rebuilding. Ya need a method for compressing the servos for rebuilding. Ya need a method for cleaning parts that involves the use of a hd petroleum-base solvent, (not the water-base shit). The list goes on...the munroe book has the details.
I'd highly recommend that you actually do a build of your existing sii 727 that is already proper for a Scout II 4x4 transfer case mate. No need to gut out the wrong transmission and end up mixing parts that May not be compatible. See this thread:
http://www.forums.IHPartsAmerica.co...t-407-tf727-variations-parts-differences.html
And...how many times have we seen the "just been overhauled" statement end up actually meaning "a po project that failed"??
If you are going to learn this stuff, then start out on a unit that is a known runner but just tired! Not some other problem child with unknown issues. I deal with this "mixed parts" deal constantly now, folks have really scruud up these trannys over the years using junkyard shit that is wrong and then end up pawning the pile off on someone else!
But then,...we see the same thing around here all the time regarding engines also!
