What rigs would the motor mounts work from? I'm going 4.0l with efi (same mounts as the 232 and 258) to go with the ps and pb I'm putting in to make it drivable (I broke my right shoulder and left hip, so driving stick is in the past for me)
I have an '89 Jeep comanche for the motor and trans (2wd aw4 overdrive) with newer efi (I only need to change the flexplate and intake for it to work with the high output harness I have)
I scored a Ford 4x4 ps box for crossover steering ('73 Jeep j4000 front axle appears to bolt right in and parts are readily available) I know it's a scrambled mix, but I hope to enjoy this rig for some time and I have most of the parts already.
Too bad no-one wants a decent running bg241 with new starter and fuel pump for cheap (it'll probably get better than 10 mpg now, but I can't drive 4 speed anymore)
