Michael Mayben
Thanks for putting up the stuff carl! I was gonna ask ya if ya still had the pics regarding your findings from a year ago!
Also...another confusing issue, maybe you can explain this based on your experience in dealing with IH parts at books:
as May be seen in the shots, the p/n suffix is all that appears on the actual part for id. And of course, that is a real advantage for identification.
But...the parts lists for the various drive gear applications show service part numbers to carry the "r91" and "r92" suffixs.
Are the "r1" and r2" suffixs to denote oem part, and the "r91" and "r92" suffixs to denote a service part?
Also...I have several "price lists" which were current in the 1981>1985 time frame for all parts from all IH divisions. And neither of the cam drive gear p/ns show in the price list under either variation. And nothing in the supercession data either. I simply can't see those parts going into the "obsolete" column when the motors continued in production up through the mid-80's.
Robert...I've yet to run across an "r3" or "r93" gear set. But Jeff mentioned that he has seen 'em. He might have a set in some of his used stuff, but I failed to sort through those when I visited ihon last month. There were some gears I found inna box though, maybe he can get zaed to dig through 'em and look for the r3 set! Put that boy onna mission and he don't give up if ya tell him a dollar is involved, he'll make an r3 gear set!
Based upon a previous discussion I had about this with Jeff a few years ago, we "thought" the "r3" (or r93?) gears would have appeared maybe around the late '77 time frame for the "next tier" emissions motor apps represented in the '78>'80 Scout II platform. But again, the Scout parts list for that point in time (mt 130 published oct./1980) does not show an r3 or r93 gear set p/n, it does show the r92 set as a service part.
So again...based upon what we know right now Robert...the fact that the aftermarket replacement gear set is all we can currently obtain new when needed, I'd say all our figgerin', bs'n, and calcs should be done with that set as a constant.
Regarding the lack of documentation and anomalies regarding tim's motor build from ***(my edit), I continue to get bits and pieces of similar "issues" trickled in from various sources who have experienced the same or similar. Seems the output of that operation can be a bit "erratic" at times and has been for many years! We got lots of lurkers watching this thread which has stimulated their own concerns!
I guess I need to pay more attention to the details.
