Michael Mayben
Ain't it more than a coincidence that this same scenario plays out over and over?? You should see the volume of email I git on this same subject from folks who don't wanna play in a public forum!!!
And you are absolutely correct regarding the pertronix instructions. I have written to them many times about that and even developed a "draft" revision of the instructions. They have never responded to my attempt at assisting them inna "qa mode". And because many times the aftermarket replacement gold box units have a different color pigtail (even though the plug will only engage one way), that adds to confusion.
The "up and down" play in the reluctor segment is of no concern. That is the "movable" segment of the mechanical advance unit and that movement is normal due to it's design and method of retention. Do not attempt to pull it up or it's possible to destroy a retaining clip underneath the lubricating wick below the rotor.
The only way to measure/detect "end play" in the distributor drive is to remove it and measure with a thickness gauge. The drive shaft and the part you describe mesh with each other but there is not a physical connection.
When the Holley gold box system is fully functional, it's a fine ignition unit. Same for the pertronix conversion, they are basically the same technology, only the pertronix does not require a separate amplifier. Because both are electronic triggers, you will not notice any performance difference at all, you have not done anything to make any difference other than restore the ignition system to functionality.
When you installed the p-tron and then adjusted the air gap to 0.030" with the supplied gauge, that "set" the dwell on the unit forever (unless ya change it). From then on, all that is needed is to set/verify base timing.
Changing to any of the aftermarket coils won't do shit as far as "performance" upgrade, the stock coil is just fine.
The only effective upgrade from where you are now is to add in a "6 series" cd box from mallory, crane, msd, etc. Along with a "e" core coil of some sort with a primary resistance in the 0.4>0.6ohm range. With that set-up, you can open the plug gap to a max 0.045" and you will feel a noticeable seat of the pants "change" in overall performance, especially starting.
The system described would be considered current state of the art without going distributorless/crank trigger/coil-on-plug.
