I have a 77 SII, 196-1bbl, 4sp, D20,d44's, p/s, p/b, 2 inch lift with 2 inch body lift. - Basically Stock.
Looking for some thoughts re: the power steering box and "any" adjustments that are possible. I have just a tiny bit of "play" in my steering when driving. Put the Scout on jack stands, took off the front tires, and played with the steering (back and forth) to see exactly where the "play" is. The Scout drives just fine at 60-65 mph, but I would like to see if I can get the "play" to go away. Frame is not cracked, and I have steel plate on both sides of frame where steering box bolts on. I switched from the stock rag joint to the older "bell" steering coupler (feels a little bit firmer/sturdier)
Seems that the steering box has about a 1/4 inch play from steering column to wheel rotors. At the steering wheel, maybe 1 1/2 inches either way from center. I notice that there is an adjusting nut and lock nut on top of the steering box and was curious: what is this adjusting nut for? Is it possible to "tighten up" the looseness in the steering with this adjusting nut, or is it for something else? any thoughts are appreciated.
