Speedometer drive gear
blhensley
Im in need of a Dana 20 speedometer drive gear for the t-18 transmission. I tried one from a 3 speed and its a no-go. The cable broke off inside mine and no way of retreiving broken piece. The gear gas 12 teeth on it. Thanks in advance!
I wish I had the t-19 when I installed my t-18, better trans. Having 1st syncronized! You probably dont want to take parts off a good t-19.
Here's the 1 offa t-19,d-20...has 13 teeth,May wanna count your's again.Jeff
I can definately count 13 on yours by the clear pics you posted...I do appreciate you trying to help on this though!
I just took apart an t-18 for parts for another t-18 rebuild. I May have what you need. The parts are at a friends shop so I May not get to it for a few days, but I will look....12 teeth correct?
Fred
Sorry, I had the transmission only from a 4wd vehicle. There is no speedo gear on the tranny it is on the tc which I am using. Sorry didn't work out for you.
Fred
Thanks for trying fred! I finally got the old one to where it's working for now, but dont know how long it will hold up! Thanks again!
