Ok, looks like we have correct verified info posted now.
I don't wanna "argue" with the niehoff dude either...but those folks read from a screen! And no doubt...his "screen" tells him the "specs" for that coil. And, he's correct! But he is regurgitating "company line" based upon parts consolidation! I mean...even pertronix "tech" gets it right in that respect! And they are real smalltime players with the coils outsourced through messkiko and china.
And an "internal resistor" coil is not the same thing as a "use with external resistor" coil !!!! The primary circuit wiring for those two totally different items is not the same!!!
But...has he ever actually measured "correct primary current flow" inna four cylinder, point-triggered, inductive ignition system??? Hell no, there ain't nobody even produced any engine with that setup in the last 25 or so years! In other words there is hardly any market for a coil of that spec except for the folks that play with 6popper chev and Ford and chrysler restos (or hillman minx, humbers, or a mg magnette)! And us (all 20 of us in the u.s.!!).
I'm tellin' ya, the "lower" resistance coil is perfect for a points v8 app...no discussion there!!! But not for an IH 4popper with either a delco or Holley distributor! And we've not even mentioned that some of those engines were equipped with the gawdawful lucas distributor! See all my previous posts regarding sv (not I-4) ignition guapo!
"doing the math" on this kinda stuff means nothing other than a starting point (maybe)! The "math" is all dependent upon a perfect set of conductors, terminations, constant/fixed voltage/current supply, and lab-condition temperature control of components! I used to do this kinda product technical support crap for living (12 years)! And that is what service manuals are written around since they "specs" are pulled from "math" and engineering data...not real world!
But the only thing that matters is the real world, when the motor is running at an underhood temp of 235*f, with a battery output that varies with engine speed (generator/alternator rpm) with "average" condition wiring/wire terminations.
This ignition stuff is not a "one size fitz all" kinda deal like the aftermarket parts manufacturers like to make an end-user "think" that is the case because they no longer supply all the variations of components that there is no longer a market for! So they look at "similar" stuff and make consolidations with nothing optimized for individual systems except chryfordrolet! And there is even less of a market for breaker point ignition systems/components!
And this situation constantly changes! Right now, there are many parts in my dbase that were plentiful from multiple suppliers just 2/3 years ago...no problem finding on the shelf anyway, not "special orfer" stuff. Now those numbers are nla in one fell swoop since the primary manufacturer of the part in question no longer produces. That means all the re-pak/private label "brand names" disappear also unless residual inventory is sitting in some wholesale distributor "dead stock" dark warehouse corner!
That is why we're always looking for new sources for this stuff and this only comes up when someone discovers the "nla" excuse! Just you posting this thread, has stimulated me (and others I'm sure) to see what alternatives are out there! Otherwise, I'd would have never scruud with this until someone else brings it up...or I need a coil for my shop/use and go to town and find out I'm sol! Then it's back to the office to do the research and try something else!
But a modern day, retail auto repair/parts operation can't spend the time and money doing what I and others around here do for a hobby! They just advise the customer to "trade it in"! Customers won't pay for hours of research on the I-net trying to find a part. Exactly what most shops won't even talk to ya about fixin' an IH product, they'll just say "can't get parts, take it to the scrap yard while steel prices are high"!
We're a bit different around here...the ihon business depends upon finding the right stuff for the customer, many times it's not quick and ez, many times it's real pricey, but that is what this business is based upon! That's called a market niche!
