Sloppy 74'
gulfdawg
The shift linkage for my truck has finally failed. There is so much slop it will not go into low. I am talking about an automatic tranny to avoid confusion, and a 1974 pickup. After the column, to the trans it is as loose as it gets. It looks like there used to be some nylon bushings. Those are gone and I have had no luck locating any. Has anyone else encountered this problem?
The '74/'75 fullsize stuff has much more problem with this than the mid-'72>'73. That is because the shift components in the saginaw steering column are sync'd for a hydramatic division t350/t400 slushbox shift control...in other words...GM shit.
And for the torqueflite, there were many different shift levers on the valve body provided by chrysler for various apps/platforms both in-house and the stuff they supplied to IH and amc (and others).
Once the column components become worn, the control action goes to hell and can't really be "adjusted" any longer.
However, it can be improved by simply starting at the top and working down, eliminating slack at every possible pivot point. That May involve drilling some of the connecting holes oversize and installing some delrin or nylon bushings as found in the bins at any full service hardware department. Those same hardware selection s also will contain bronze/oilite bushings in common size which have a flange or shoulder on 'em.
Just rip all the controls out and be creative in removing slop.
Or...install an aftermarket shift that mounts to the tranny hump and uses a cable, the tranny mounted aftermarket shifter for chrysler apps most likely won't work in the IH truck due to the seat location and placement of the tranny under the hump. The cable shifter allows some flexibility in mounting.
After looking for the bushing kit with no luck I was told to go to aamco. I have in the past dealt with this shop and they seemed to know what was going on. The guy there had me leave the truck and he said he could have it done in a little bit. I ended up dropping the truck off late and he called me the next day around 12 and said I was all good and ready for pickup. As soon as I shifted into reverse I could tell it was fixed. The column shift was accurate and solid. The guy there said all they had done was replace, or install two bushings, and adjust the linkage. For anyone with this type of issue I would recommend this shop. Aamco, livermore CA
