david30101
After installing transmission after rebuild. I found that all forward gears have little or no movement of truck. Reverse is strong and holds good. Slips real bad in drive, 2 and 1 positions. I have a new accumulator piston with double seals. I did the air test on the kickdown servo and reverse servo, all was good. I did clean the valve body and made sure everything is back together same way. It has all new clutches and bands. What gives?
