Howdy yawl. Does anyone know if the sii blower motor was the same for the entire production run 71-80? I have a suspicion that 1980 was a different call out than previous years. The reason I want to know is this: hooty has a stud mount two-speed motor in him right now that's working reasonably well. I have it on good authority though that a heavy duty flange mount blower motor that crosses many GM vehicles from the mid 70's thru early 90's and also by coincidence crosses to IH Scout II (depending on which parts source you refer to) puts out considerably more velocity than the oe stud mount motor. One parts source lists both a stud mount and a flange mount motor as being applicable for sii's regardless of m/y, like the choice is up to the consumer. Another online source lists only a stud mount part number for sii's from 71-79 and then the flange mount for 1980 only. Pictures that I've seen of 1980 engine bays indicate that the motor May indeed be of the flange mount variety. I'm wondering if there's be any reason why a flange mount motor couldn't be subbed in place of a stud mount motor provided the rotation and all vital measurements were the same. For the mere pittance of $18 at napa, I think this is worth a try. I suppose I could always return the thing if it obviously won't work provided I haven't made any alterations. Just wondering if anyone has been down this road afore.
