towpainter3
Just pulled the motor and trans out of the Scout. The snout on the converter is worn and shiny around the nose , flexplate and torque con bolts were tight. Pump bushing bad or worn out? Didnt pull the converter out yet but it was pulling fine and shifted great. Will pull tomorrow nite and check hub side for wear. I would like to use this converter due to the drain feature thats not present on the 80 model any advice or suggestions would be appreciated thanks
