scout-it-out '79 scout II
Not related to the transmission but... I got a new spare tire!
I did get some more work done on the trans. Pretty much all that's left is to put the valve body back in and install a shifter seal.
I've been meaning to upgrade my alternator for a while now. I wanted a 12si but the parts store didn't have it. So they made me a deal on a 15si. I never heard of it but after some research it is most likely 78 amp. I think it's the same family as the 10 and 12si. Same plug and one post. So wiring was a no brain-er. I did run a 10ga wire directly to the battery so as not to overload the stock amp meter or related wiring. The case on the 15si is bigger than the 10. The only way I could get it in was to make an access panel. The adjusting bolt is larger, 3/8 vs the stock 5/16. A few min. With a die grinder made it work. The new alt. Works great! At idle with the ac and elec. Fan on, I'm at 14v. In drive I still have 13.5v:d
I've been working on fastening down things in the Scout. Here's my most recent solution for my jack.
Well, no sooner than I fasten the jack down, a tire separates on me and I have to use it! On my way home from an impromptu snow run and the steering wheel starts vibrating. Finally it got so bad I had to pull over. Sure enough the driver front had a big bump in it. I found a nice sam's club parking lot and put the spare on. Ups just brought my new cooper stt pros today:d:d
weighed my Scout today, 4800 lbs.
1/2 tank of gas
custom welded bumpers front and rear
10lb co2 tank
large fire extinguisher
tool bag
bottle jack
31" spare tire on steel wheel
i've had one electric fan for a while now. for some reason i thought there wasn't room for a second one... i was wrong:D.
in the process of wiring the second fan, i found i didn't like the way the first fan was wired. so i rewired both of them! that ground in the foreground is just for the relays.
Nice. Both fans will help. Also hope you didn't use those POS straps that come with most electric fans that go through the radiator. Many years ago, I personally ended up with a bad radiator because of them. Also had to replace another radiator last year in a friends scout because some other shop used them.
i did use those special zip tie things one one side of each fan. they are not through the radiator though. they're fastened to the ac condenser. the OE condensers are very sturdy, plus i have a spare, lol. thanks for your concern.
In the process of fixing door hinges for my Scout project, I decided to do the ones on my green Scout. Two of the hinges had broken pins when I bought it so I just replaced them with some spare hinges I had lying around. So I rebuilt the factory green hinges with new pins and grease fittings and installed them today. Best thing about it is, the little friction pads were intact so my door doesn't close on my leg anymore!
Christmas tree/ snow run up East of Chico near Butte Meadows. i was the only scout.
Hey Jeff, I found a new use for that fly swatter you gave us! works great for clearing snow away from the valve stem when you need to air down some more.
So I finally got tired of modifying wiper blades to halfway work on my Scout. I got a couple of wiper arms from the wrecking yard with the new hook Style. Then cut off the last two inches. I then drilled and tapped a hole for 8-32 threads. I modified the little plastic washer for the wider arm. I can now buy wipers at any auto parts store that carries the 13 inch!
My smog pump started making a grinding sound. Rebuilt pumps seem to be rare and expensive. I found this pump (Cardone 32436) that looked perfect even though the numbers say it's different. Turns out it's about 1 inch shorter but will work. I made a spacer for the bottom bolt, 1" long, 1" od, 3/8" id. Top hole isn't threaded so I put a 3/8x 3.5" bolt through with a nut. The pulley and valve mounting holes are metric. M6-1.00x10 and M8-1.25x16 respectively. The M8s could be a tad longer if using a lock washer.
Just reminded me. I may have an OEM smog pump laying around and stuffed inside my storage unit somewhere. I have no use for it
