Scout II Spring Main Leaves Front and Rear
I've got a set laying off to the side, that I keep tripping over. At least the fronts. And I have the rears somewhere in my cave. Located about an hour south of ya.
They came from my rolled Scout when I stripped and scrapped the body.
Sent ya a pm. I know I have the fronts laying on the floor in one spot. I need to make sure the rears are there too. Might in another spot in my cave. I'll double check this evening when I get off work.
Works for me. I'm not looking to get Rich off them. Just getting tired of tripping over the front leafs. Plus, not not sure when or if I will ever use them again. Too many other projects going on. The fronts I have laying on the floor. I need to finger out where, in my cave, I place the rears.
Another message on the way.
Hello,
new 69 800 Scout owner and rookie to all this. Couldn't find a place to post a new forum but wanted to see if anyone knew why my vehicle only has 2 gear shifters on the floor where there are other scouts that have 3.
hello,
Welcome to the forum
this question could be posted as a new thread in the "basic tech questions" section.
One shifter is for the transmission. And the other shifter, or two shifters, are for the transfer case. Most transfer cases usually need only one shifter to ingage into 4x2 and 4x4 low and high. Some people set up their transfer cases with two sticks for 4x4 engagement. Which is why some rigs have three shifters. That'sthe basics. There are other options for why a third shifter is there.
Thank you so much!!
I just bought the line setting ticket for my vehicle. Is there any tools out there for decoding it? Like for example...id love to know what the orig paint color was and it says paint chart 1135 4298g0 4274898.
thank you so much!!
Again, not to be rude but, instead of hijacking this thread, please make your own new post in the general tech questions section elsewhere in this forum. You will get better responses posting in your own thread
cool just replied to you.
I know for a fact that I have the front pair of complete spring packs laying here on the floor in my cave. Thought I had the rears laying around too. Then it just dawned on me a few minutes ago that they were taken by silverscout. Somewhat an arranged swap while I built his roll cage.
If you still need at least the fronts, let me know. I think I sent you my contact info in pm. I will be hiding out in my cave, drenched in grease, grime, and dirt, while I do transmission swap on my 'ole yeller'
