The door and lift gate locks are fairly simple and straightforward to change. The column key switch tumbler is a little trickier to remove. The Scout II's utilize a saginaw style column common to millions of GM vehicles of similar vintage. If you do not have the service manual for your Scout (highly recommended and available from IHPA), this process should be well covered elsewhere, both on the 'nets and in GM service literature.
