Chris Pucci
Active member
are you still needing a tranny? I have a good one sitting in the garage.
Sounds like alot of fun and you get to do it on someone else's dime. Not that you would spend alot of course.![]()
Tranny: sold!!
I'll take it.
and I gotta pair of sii axles (disc front) in the shop that need to go away (came inna swap from monte originally). The locko hubs are gone but everything else is there. The brake system on the rear axle is new and fresh, doesn't appear to have actually been used. They are geared 3.07 so they would be cruiser gears for sure. Vintage post-'77 we think as the bom numbers are not in the database.
I'd have to surmise that is a "early" sii, maybe a transition version from the 810 based on the mounting of the data plate. So ya May find "features" of both versions as ya work through it.
it is not an 810 -- I checked the glove box and it is a Scout II -- my '72 has all the same quirks that this 1971 has, vin tag and line setting ticket on the cowl.
I should compare the vin numbers between my Scout and his Scout and see how far apart they actually are -- mine has a production date in 1971.... They might be closer brothers than I think!
axles:sold!!
I'll take them.
3.07 might actually be just what he needs for really driving around at freeway speeds in cali. - it would put him at about 2450 rpm's at 75 mph. Just about perfect for cruising with a 345.
I am curious myself. I have a 1971 that is an 810. I wonder what the production dates are between the two.
my '72 is: g469232
my bro's '71 is: g464100
so we are only 5132 builds apart.
I couldn't find a build date on either LST...
chris, have you thought of throwing in a TBI set-up?
my 1971 810 is g454136. Just in case anyone was wondering....![]()
so how soon will you be ready for body and paint work?..![]()
