77 SSII, 345 2bbl., 727 tf, headers, pertronix module, truetracs front and back.
I am hoping this is going to be an electrical/ignition problem. Scenario: it's 85 degrees today, I am on the freeway, I notice while going 65 mph a slight hesitation (like the Scout is starving for gas). I am off the freeway sitting at a light, temp gauge shows 190 degrees. All of a sudden, the Scout stutters and dies. I push it of to a side street, let it sit for a few minutes, try to start it, no go. It cranks over fine (brand new battery), and for a second it sounds like it wants to start right up, then not. Wait a few more minutes, try to start it, for about a second, sounds like it wants to start, then no go. Checked fuel, good squirt down the carb, check distro wires, all news (6months), coil seems to be rather warm.
While waiting for tow (about 45 minutes) try to start it, boom, starts right up. Temp gauge still shows bout 180 degrees. Let it sit at idle for a couple of minutes to see if it stumbles, it does, but then it smooths out.
Got back on the freeway, got back home (about 12 miles), got Scout in the driveway, turned it off. Let it sit for a few, then try to start it, starts up just fine.
So, this happened twice before over the last nine months and only in hot weather, never in cold weather. Its gotta be something electrical. Called pertronix help desk. Explained what happened. Techs thought was that it might be a wire that is heating up causing resistance and killing the juice to the disto. Or I am thinking the coil is getting toooo hot and maybe causing this problem. However, I had the same problem before and thinking it was the coil, changed it out. So back to a "weak" wire? Tech mentioned that the ignition switch hot lead might be the problem (but the switch is on the steering column), how would it heat up? I will research this (look at every wire) but I am open to suggestions. When looking at wires, what am I looking for?.
