Chris Pucci
Active member
Dan - when are you going to ditch the external hubs and go internal? Then you can run drive flanges and never break a hub again....
I'll even help you do it!
dan - when are you going to ditch the external hubs and go internal? Then you can run drive flanges and never break a hub again....
Looks pretty normal.I'd go but there is something wrong with my Scout. I put it in gear and nothing happens. I just don't think I am getting power to the axles....
Have fun and be safe!! And if you get stuck bad and need advice at 3am -- give me a call, I'll probably be up kickin' it with max.
we talked about that today, and I just got done reading over what you did to your brothers Scout again. Looks really good, how much did it cost to do the entire swap?
Ive got a list of things to do before the oct cali trip, guesse I should add this to the list![]()
all brand new parts = $200. Plus you scrounge up a set of Chevy 19 spline stub shafts.
Or junk yard parts = $50. Same deal on the stub shafts.
But lucky you, I'm getting out of the d44 business and have a set of stubs I'd give you -- if you promise to ditch the junk external hubs! (I was going to keep them for the next axle I build, but this might help keep me from building another d44!)
I have the slugs he needs, but I think he still wants to run hubs because of his front locker.![]()
I might still want the slugs to put in when wheeling, but for street driving I'll still keep the hubs, and as long as im not bouncing off the rev limiter on slippery rocks, my hubs should hold up fine.
sounds like it's decision time.... Trail rig or street rig.
Ya can't have both! (without serious compromise)
And honestlly the only reason I dont want slugs on the street is because of my aussie locker.....
run the locking hubs for starters, carry slugs as trail spares.
If you start running into issues of blowing the internal hubs apart all the time, then run the flanges for the trail and swap them out for the street.
*I* predict between the GM stub and internal hubs you'll be much stronger to begain with you'll be running into "other" issues :d
ashford:
as for the dodge stuff, it sucked and I never got it figured out....still sitting in the corner.
Mike I remember uber was having problems with the rear ARB. Not sure if any of the following is anything new, but it looks like the solenoid is rebuild-able. ARB has directions here. http://www.ARB.com.au/resources/pdf/airlockers/5-07.pdf .
I also looked into trail fixes for a bad solenoid, found this, mcmaster-carr[/url ] , assuming that the ARB fittings are npt threaded (couldn't find this bit of info online) . you could just pull the lines out of the solenoid and run them through this.[/quote ]
the ARB fittings and lines are metric.
I already worked out a deal on a set of drive slugs!!
