codeman
I understand what and how this is supposed to go, but my situation is a little different. Presently, I have my bare frame upside down on a cart. I have the fangs and sway bar properly located and clamped in place. I have the shackles bolted together and roughly in their location. I'm installing new alcan springs with 3" of lift and have them in place (loosely) between the fangs & shackles. I have not drilled the frame for the shackle bushings yet.
Since the frame is upside down, without the weight of the axles, how far away is this from full droop? I have the frame resting level on the cart. Can I locate the bushings by obtaining the recommended 5 degree angle with everything as it sits now? Anyone ever done it like this???
Or, should I attach the fang assembly and wait until I have the rest of the frame fab work done, flip it over, preload with weight and then drill for the bushings?????
