Replacement air cleaner
ozzieT
Looking for a good resource for a replacement air cleaner assy for my 1976 Scout II , 4cyl , 196, carb is a Holley 1940 I think, its a single barrel. When I bought it someone had installed an aftermarket air cleaner that looks like its meant for a lawn mower, it measures about 5 inch in diameter . Any good tips?
I realize I can install about anything if I use a reducer but I'm looking for one that is designed for this tiny thing.
I'd see if you can find the stock housing. All the after market filters I've seen have the element exposed, good for hi-perf apps, but when you hit the deep water, the spray will saturate the element and kill the engine.
Good call, stock is what I'm hoping for. This morning I emailed Chad at ihparts to see if they have one on a shelf somewhere.
