The TC-145 is IH nomenclature for a Dana 20. So the answers to your questions are yes and yes since you're already there. Now, the early Scout D20 cases are twin stick, with later versions being single stick. Scout 80 models have Dana 18 or TC-144 twin stick cases. You should focus on sourcing a D20 from another 800 model like what you have, rather than a single stick D20 out of a later Scout II. It won't matter if the one you get was mated to a manual trans. All you'll have to do is swap the auto bull gear from your failed unit over to the donor unit and then it will play nice with your BW trans.
