relay for the Neutral safety switch
Looking at the relay prongs as if they formed a pyramid, the top terminal is #17a which is the + feed from your ignition switch. The left terminal is #17 which is the + feed out through the bulkhead to the starter solenoid. That leaves the right terminal which is #11, the ground which penetrates the firewall and terminates at the middle prong of the trans-mounted neutral start switch.
