Rebuilt 304 (in pieces)
I sold my truck and my Scout so this must go.
I came across a factory rebuilt 304 a while back, been sitting on a pallet for 30 years. I tore it down and had aims machine clean and check the heads and block out. Everything is as it should be, but there is a small amount of surface rust in the very top of cyl. 1. They just rehoned everything and insured me it was not an issue.
Anyway, everything has to go. All tins, have both oil pans and pumps for either a Scout or a truck, have the harmonic balancer and valley pan also. You just need a felpro gasket set and your intake manifold.
Also, I have 16 new lifters, new rod and main bearings (proper over size ) and I also have new cam bearings. The bearings in the block from IH are good, I just elected to replace them anyway since I had it torn down.
Looking for 500 bucks for everything (in reno nv). My loss is your gain.
Got your e-mail from 11 last nite nite thanks I'll take it all 700. I;m now attemping to arrange the transportion end of this I'll call and advise you, do you have a contact place were I can get the gasket set at a good price? And new water pump?
Yep, I second that.... You cant beat Jeff's prices plus your supporting the community
now, let me get back on track. I sent you an pm this morning. Obviously I was smoking crack last night and fat fingered my all inclusive offer to you. 750 for everything, not 700. I am loosing cash on these sales and I refuse to budge 50 bux. The alu intake was 500 when they were in stock, and the motor has about 1300 in machine work on it.
As for water pumps, you will need to get with Jeff and get a volute, pump and tubes. These where not included by IH on their rebuilt motors. I was planning on using my existing pump of my 800 before I sold here.
So, if you are good with 750, then we can deal.
Hey michael did you get the ck I asked you to call me I left you a message, get back to me, I guess you don't quite understand I need to make my arrangements to go up to reno and p.u. The engine and misc. Let me know asap! David this is Sunday, pm I'm planning on p.u. On tues.!
