Michael Dimock
IH Parts America Sales Assoc.
I have a 1962 International Scout with a rebuilt ic 196 out of a Scout 2. It is running a 260 grind performance/towing cam, has a cast iron delco distributor with dwell set at 75*, new coil, plug wires, and points with about 1000 miles on them. The distributor has been shimmed to reduce the shaft endplay. I'm running a Holley 5200 carburetor that has been rebuilt by m mayben 9 or so months ago. The gas in the tanks is 6 months old, so I'm unsure of how good it is. I finished off one tank and it now has a gallon of new gas in it. I just switched the engine over to run off of that tank.
It seems to be running lean/hot as after about 5 minutes the exhaust pipe and manifold begin to start glowing. When I drove it down the highway a couple miles with the engine under load the manifold cooled down to a very dull red/barely visible glow.... Continuing on, I've tried multiple positions of the distributor and all result in the manifold glowing. Sometimes when I shut it off, the engine will run and fire a couple times and then run quickly backwards.... This is caused by retarded timing and excessive unburnt fuel correct? If that is the case, shouldn't my exhaust temps be low enough to not cause the manifold to heat up excessively?
Can this $#!%y ethanol gas degrade enough and absorb that much water that it will cause my engine to run excessively hot? I haven't run enough of the new gas through it to make a difference yet, as it was already glowing when I switched it over....
well, I'll advance the timing and most likely see my glowing manifold go away! The new gas might help too!
