Rear shackle placement?
Rentalman
Active member
Happy Thanksgiving All!
I've been going thru the shakedown test on the Scout II since I finished restoring it. I discovered an error and need advice on how to fix it? My rear shackles are not hanging correctly. I discovered this yesterday while lifting the rear of the Scout and resting the frame on some jack stands to remove the rear passenger side 4" Skyjacker Spring to add the 1/2" spacer. I noticed when I removed the floor jack. The weight of the axle dropped the springs and the 5" shackles moved forward. I would guess if I were off roading and the springs get compressed back from that position the shackle would possibly colapse inward instead of going towards the rear bumber to lengthen the springs.
Unfortunately my lack of knowlege plus Skyjack's installation manual had no mention of,"if your using longer shackles you should relocate your rear spring hangers forward a few inches". The bummer is I had new CPT spring and shackle hangers welder to the frame. Then had the frame sandblasted, epoxy primed and painted. Anyway you live and you learn. Now I need advice on how to correct this.
If I were to send this to a shop, they would need to remove the gas tank, cut the hangers off, relocate and weld back in. Then I would need to restore the paint. I'm guessing that would be a $2,000 repair.
The less expensive option I'm thinking is to have some custom longer rear springs made. I'm guessing they would need to be 2" to 3" longer. Deaver Springs is local to me. I would install them. I just do not know if this is the correct fix? The rear of the spring would be 2" to 3" longer than the front of the spring. The center pin would not be in the center. Currently with the weight of the scout on the ground, the forward side of the driver side rear tire measured at a diagonal from corner of front of rear wheel opening to tire is 1 5/16" (or 2 fingers width straight across) and the passenger side is 1" (or 1 1/2 fingers width straight across). When we welded the new CPT spring and shackle hangers in we used the center line position of the eye on OEM hangers. They are 5/16" off from one another.
I've put 600 miles on the Scout now. It starts everytime, runs great and doesn't over heat anymore, TF727 shifts correctly, Dana 20 can get into all gears. The rebuilt Dana 20 does make a little noice once you go past 35 - 40 mph. No gear noise from axles being rebuilt. I intend to send my steering gear out to Red Top after I get the rear shackles hanging in the correct position. I'm sure the way they are set up now may have some affect on my steering?
I've included some pictures and some measurments for your viewing to see what kind of mess I got my self in.
As always, your knowlege and advise is much appreciated.
Have a great day!
Rentalman, I have a similar problem and the guidance on this site I received was the rear hangers need to be cut off and moved forward 2-3”.
I called Deaver about custom springs and also a shop about moving the hangers. I haven’t decided which route to go yet. I’m in Los Angeles area. Seems like Skyjacker lift springs would be built the correct length to not require moving stock spring and rear shackle hanger mounts but I don’t know.
Good luck with your ride, I’m interested in what solution ends up working for you. Take care.
Stretch, I'm going to call Deaver this week. I hope longer springs will be just as good of a fix as relocating the spring hangers. For me that would be a simple fix. Unfortunately I'm not a welder, otherwise I would pull the fuel tank and relocate them my self. I will let you know which route I take.
Stretch, since I've realized my shackle hanger issue I've researched it further. The 4" springs are the correct length for the Scout to install up to a 33" tire. With those springs we need longer shackles so when the 4" arch in the spring compresses getting longer the 5" shackles will articulate the lengthening spring towards the rear bumper. Unfortunately yours and my hangers are in the stock location. My shackles pretty much hang straight at the rear. I think they need to be angled at 35 degrees to work correctly with the suspension.
If you know exactly where you need your shackle hangers located I’ve seen certified mobile welders at ballpark $100-$200 an hour. R/R the shackles should be an easy lesson than few hours job. Then reshoot the area. That’s the direction I’m going with mine. I’m just need to get to the place where I am certain I know where the hangers need to be so the certified welder just has to be good welder and R/R them where I tell him.
Sketch, thanks, that's an option to have a mobile welder. I will give Deaver a call to see what they have to say. I just don't want to go thru the trouble of removing the fuel tank. But if I have to I have too.
