I have a 1970 1100d- trying to verify rear axle. Appears to be a dana 60 but everything i find sys they only put 60’s on 3/4 tons, mine is a half-ton but 4 wheel drive. Help!
Most likely a Dana 44 if it is half ton but there was an option for a Dana 60. If the pumpkin size/differential cover is the same front to back, then you have confirmation that it is a Dana 44.
Other clues include wheel lug/stud count and the presence or absence of a bulbous hub protrusion and corresponding circle of bolts for the full floating axle shaft found on Dana 60 and larger axle groups.
