Erik Socha
I have been messing around with my new project over the past few weeks. One of the things that I noticed was a manual choke in the cab of the truck. I thought that this was odd since I have a 1974 & 75 Scout II and neither one of those have a manual choke. I removed the air cleaner to get a closer look and this is what I found......
there is a automatic choke box...however, the rod is disconnected.
You can see the choke cable and the very dirty carb.
then I checked the other side of the carb and noticed this...???
some #'s that I located.
1705721.....there are a few more #'s at the end of this but I could not see them.
3386 awp
anyways, since this an IH I would prefer to go with a oem type carb. I believe that IH used a carter thermoquad carb on the bigger IH v8 motors. If this is the case should I go with the thermoquad. Or some other brand.
I know that I would like to get rid of the manual choke and go back to the oem setup, ie.... An automatic choke.....
Any ideas????
3386 awp
Any ideas????
