Project IronScout
Looking real good david!
My only concern/suggestion is where you powdercoated the spindles and caliper supports. Any surface that is bolted together such as these two parts should not have any paint/powerdercoat/dirt in between them as this May cause the parts to eventually loosen.
looking real good david!
Thanks for that Jeff. I will take your suggestion to get rid of the powder coat from those areas.
Took some time to work on the top. Pulling out the side windows.:shocked: thanks for the info from ihochad ;:icon_up: I was able to get the windows out in about 15 min and in one piece.:yesnod:
old window with nasty tint ready for the fight.
Its a start. Getting to this point is a little nerve racking. Watching the glass flex a little:shocked:
From the inside front. Looks like some rust to deal with.
Went to home depot and picked up 5 plastic scrapers. Working with screwdrivers made it a lot harder and it felt like I was going to break the glass. The plastic scrapers worked great.
Glass out. About 15 min.
A little rust.
Time to scrape all the old tint off.
Right side vs. Left side.
I'm going to take the advise from ian from extreme 4x4 to the next level. I'm going to save some weight by building my front bumper out of cardboard. :yikes: I don't think it would stand up to a toyota prius. Or would it?
My material.
Getting there.
Now its time to cut up some 1/4" plate.
Putting on my rock sliders. My plan is to place to tubes through the frame.
Frame is marked and ready for cutting.
Plasma cutters are awesome.
All cut.
Rock slider in place ready for the welder.
roll cage time.
Starting out with my three 20' dom 1 5/8 120 wall tubing.
After putting my measurements into my bendtech pro software, cutting the first tube, and putting it into my jd squared model 4 bender. It is time to start bending the main hoop.
One of two hoops done.
Bending the front part of the cage.
So far so good. All square. Next is main hoop 2 of 2. And the rear section.​
Putting in some auto meter phantom gauges in IHOnly north's dash.
So far I have volt, vac, fuel level, oil pressure, and water temp.
Naked.
I need to get my tac, and speedo.​
been working with my bendtec pro software. Finished bending 1 5/8 dom shock hoops for the front.
This is the shock mounts I started with. I was not going to use them because I would not be able to use the steering box. So hoops were in order.
Holes drilled through the frame. The hoops will be going through the frame.
Inside of frame rails.
Hoop in place.
Coil over installed.
PA170097.jpg​
finished with the front right hoop. Its time to get the shocks in the rear installed. Here are a couple of pictures of the axle mount that I started to fab up.
PA240106.jpg​
after cutting all pieces for the axle mount with my plasma cutter it was time to put it all together.
Couple pictures of the welded up mount.
Tacked to the axle.
Top mount
Left side finished. Now for the right side. :icon_smile:
PA260114.jpg​
Great work...
But, it looks like your shocks are not the correct length (fully compressed / fully extended) for your suspension. Looks like the rear shocks will definitely bottom out -- and possibly the fronts, also. It does not look like the pictures were taken with the suspension "fully compressed"...
great work...
Thanks for that. I have exercised the front and the only issue is tire kissing the very front of finder. I will be trimming that and I will still be good in the front. For the rear; it might be close. I have 5" of compression and 7" of drop out. I uses my jack and jacked it as high as I could get it and I was close. It looked like every two inches the axle went up the shock would compress one inch. So hopefully when I get my tires back on and get the fork lift in place, everything will go good. Ive tried to get the correct shock and other parts that I ordered from the company I got the suspension from and I'm still waiting. Its been over a year of waiting. I gave up. I'm sure I will be getting a set of Bilstein shocks from IHOnly; and I won't have to wait a year to get them. I welcome some advice. What shocks would you use? I was trying to copy pd's drive train and how they set up his shocks.
If you do run into problems this is a link to jegs for the screw on type
mr. Gasket shock extensions - jegs
There is also these but I do not like the design too well
https://beedspeed.com/product_info.php/cpath/78_160/products_id/5648
But I thought of the idea of just using some dom tubing around the shock weld some tabs to the tubing that will work with your shock mount and just run a bolt through the tubing into the shock mounting tab. But this is just an idea I had while sitting around so do with it what you will.
I have no clue as far as a shock you could run.
Hopefully you just don't run into problems in the first place.
Oh and what would you recommend as far as springs to give me about a ride height about where yours is.
I have been in a toss up between leaf springs and coil springs. I could probably even set it up in class when I get to the point because I will be building them in class I just need need to decide.
oh and what would you recommend as far as springs to give me about a ride height about where yours is.
Blake, the real expert is Jeff at IHOnly. He would be able to give you the best advice for your set up. What is on my truck is a race runner series 2.0 with a coil of eibach 177557 up front and rear is eibach coil 178901. The rear shock is a rancho rs9000 xl. I did not get this setup from IHOnly. You wouldn't want to get the parts from where I got mine unless you want to wait two years and still wait. Stick with IHOnly.
since I had the rear wheels off, it was time to powder coat the rims.
O-ring in place
Three hours of work and awesome.:winky:
All put together and aired up.
PA290122.jpg​
