I bought my first IH, a 73 1110 Travelall, last fall, and I'm getting things ready to drive. It has an improved cooling 392 matched to a 727 torqueflight. I had the heads done by a machinist who used to work on the 392's for the local school district and was familiar with the engine. He also rebuilt my Holley 4150. I put everything back in and added a dui, stan's headers, and a new radiator/ electric fan kit from sparky at rnd fabrications. Everything was going great until I fired it up. I started it up and ran it 2 or 3 times for about 30 second intervals and it was already burning the vht flameproof paint off the headers, but only on cyclinders 1, 2, 7, and 8. Cylinder #4 is partially burnt, but not too bad. Before we get to up in arms about what paint I used, forget about it. The paint just indicated that some cylinders were getting hotter than others. As I checked, the cyclinders with burnt paint also had plugs that indicated they were running very lean. The others looked close to normal and seemed as if they had been firing correctly.
I checked all the vacuum lines and ports to make sure all was fine and it was. I also check for spark to the "cooler" cylinders...there is spark...a lot of it! I would think the next culprit would be valves...thoughts?
I'm new to IH engines, but I'm also fairly new to working on engines in general. I have a manual for the vehicle and I've been using as I go. I just seem to be stuck on this one. Let me know what you guys think, and what kind of info you need if I left something out.
