Tonka Toy
I have a prestolite distributor in the "new" Travelall I picked up not long ago. And I have some questions about it, because I know virtually nothing about them. When I brought the truck home, it would randomly misfire and seem to sometimes surge on the freeway. I took them as signs that the internal pick-up might be bad. (especially since the key kept getting left on acc and having the key pulled out by the morons at the car lot it was at.
) my local napa tells me the replacement is over $300!
this can't be right. So I go about verifying by replacing it with my Holley/pertronics unit. During the swap, a fried wire in the ignition switch decided to finally let go. Before I figured it out, I had switched the prestolite back in.
Since I assumed that was the problem, rather than the distributor, I decided to leave it in. But I still have the surging. Setting my timing at 0 (tdc), (reduced from my initial 10 degree setting), but it still isn't running right. It has dieseled on me when shutting off a couple of times, and the surging is still there. It feels to me like when you don't have enough total timing advance and it comes up against it. Like the engine needs more timing but can't get it. But I'm not sure. It has also developed an off-idle stumble that it didn't have before. And sometimes I need to crack the throttle to get it to fire up, which I don't believe it ever did before either.
I've never had a distributor without a vacuum advance, so I'm not sure if there is something I need to do or check that I just don't know about. I read that these are the cat's a** in the world of IH distributors, but I had no trouble with my Holley/pertronics. I want to use the best one, but I'm currently skeptical about which one that really is. And "best one" for me also includes affordable, easily accessible parts availability, since I plan on this being our family's backcountry exploration vehicle.
Thanks in advance for your help.
this can't be right. So I go about verifying by replacing it with my Holley/pertronics unit. During the swap, a fried wire in the ignition switch decided to finally let go. Before I figured it out, I had switched the prestolite back in.Since I assumed that was the problem, rather than the distributor, I decided to leave it in. But I still have the surging. Setting my timing at 0 (tdc), (reduced from my initial 10 degree setting), but it still isn't running right. It has dieseled on me when shutting off a couple of times, and the surging is still there. It feels to me like when you don't have enough total timing advance and it comes up against it. Like the engine needs more timing but can't get it. But I'm not sure. It has also developed an off-idle stumble that it didn't have before. And sometimes I need to crack the throttle to get it to fire up, which I don't believe it ever did before either.
