Pertronix
SSGTWC
I know this is probably a real stupid question, but can a Holley points dist. With a pertronix ignitor, be used with FI?
I've tried searching here and in bp, but to no avail.:confused5:
I think you need to improve your search skills.
The quick answer is no. Not if you want timing control.
Search forums
1. Sorry - no matches. Please try some different terms.
That is what I came up with using pertronix as the keyword.
But thanks anyway.
Are you searching in the correct sub-forum? Try looking under ignition, pertronix is mentioned often. Both here and bp
are you searching in the correct sub-forum? Try looking under ignition, pertronix is mentioned often. Both here and bp
No, I was specifically looking in this forum. So now that I have an answer to my question, I'm not looking anymore.
