I use pertronix now in most of my work. Been selling/using 'em since 1975, the quality back then was crap and failure rate high. Now that's not an issue. I'm playing with five different distributors here now all with pertronix variations.
Just like breaker points, you will fry one if ya leave the key switch in the "on" position without the engine running. There is a heat/over-current indicator decal on the module, if it "shows", then pertronix will not honor the warranty, that is "installer error".
Same thing happens with points and any other electronic trigger. The pertronix II version has internal circuitry that prevents this damage along with a few other features for additional $$$. If ya leave the key on with points, and the points are "closed", then they will superheat and weld themselves together in about 3>5 minutes.
The pertronix application guide is somewhat misleading regarding IH apps. You must know exactly which distributor you are using to get the correct item.
Also, a p-tron does not like a worn distributor, the air gap/dwell will be all over the place when seen onna scope...that means ignition timing will vary tremendously over the rpm range. Same for the vertical end-play (aka "gear-to-housing") factor of the worn distributor, that should be no more than 0.040", I set 'em up with 0.010">0.015" clearance for consistent timing from idle to wot. A Holley distributor I built yesterday had an original clearance in excess of 0.100" which is huge, no way to keep timing consistent!
Onna p-tron, the dwell is determined by the air gap when setting it up initially, on a curved-point Holley distributor with a #1481 p-tron, that gap is 0.030" measured with non-ferrous gap gauge (included in the package).
