Ok, so I tore into the 241 today, all rockers/ pushrods looked great, apparently overheating caused some internal pressure that blew the valve cover seal, (maybe there was no functional crank case vacuum?) anyway engine cranks over fine, so I pulled the plugs, ugh!, lets just say I don't think #1 plug has been firing for a while...(see close up)
so I bent the valve cover back straight (-ish), rubber gasket was in great shape so I resealed the cover with some right stuff so it'll stay sealed!
Next I'll do a compression check, if all is good then new plugs/wires, oil change, perhaps examine my lack of crank case vacuum issue?
See my previous post for my troubles post ihfsr:
http://forums.IHPartsAmerica.com/IH-sierra-fall-rallye/12504-9th-annual-IHSFR.html
