Bart
Hi, I ordered a new oilpan gasket here, cause mine is leaking a lot.
I own a pickup 100 with 345 and 727 from 1974, with the independent front suspension. Now I found out there is not enough room to get the pan out.
I wonder if it's possible to lift the engine from underneath, with a selfmade metal u-shaped device, screwed in the unused bolt holes on the front of the engine just above the oilpan? Something like on the second picture?
Or is there maybe an easier way to make room?
Thanks for the advice,
Bart.
Bart.
