IHCScout78
Hi,
I slathered the oil filter mounting base gasket and all the installation bolt threads with hylomar and torqued to spec.
Now the engine is in the truck, and the oil filter mounting base is leaking like crazy.
Per the service manual, I torqued to 25 to 30 ft-lbs. I thought the mounting base was stiff enough not to extrude the gasket. From what I can see in the truck, the gasket still seems to be mostly under the base but does seem to have squished out a bit. Is this the correct mounting bolt torque?
Is hylomar the correct thread sealant?
Thank you,
ken
Thank you,
ken
